Multicolumn listbox, jump 1 cell down
Cant figure out why this little VI does not work.
Wan't to move edit cell 1 cell down using return.
The edit position is -2,-2 no matter what I do.
(4,127 Views)
Accepted by topic author Michael.Koppelgaard
Try using the Edit Cell event.  Also, according to the help, you have to set the key focus in order to have the Edit Position property to work.
(4,113 Views)
Not sure why you are incrementing.
Modified vi to get the event for multicolumn list box and enables editing , if your requirement deviates modify to increment as  per your requirment
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(4,076 Views)
Because the requirement is that when Enter is pressed, the next cell down is editable.
(4,062 Views)
Great i works - thank you 🙂
(4,027 Views)
