Multicolumn listbox, jump 1 cell down
Cant figure out why this little VI does not work.
Wan't to move edit cell 1 cell down using return.
The edit position is -2,-2 no matter what I do.
Message 1 of 11
(4,313 Views)
Help file is your friend.
aputman
Message 2 of 11
(4,284 Views)
Actually that's not the problem.  The control already has key focus by virtue of the fact that a key press event happened to it, so that portion of the help file is irrelevant.
What you need to do is change the event to a "Filter" event (the one with the question mark).  The problem is that the Key Down event occurs after the editing has been stopped, so you get -2,-2.  If you filter it, and set the "Discard?" output node to True on the Return key, it works the way I think you want it to work.
Message 3 of 11
(4,278 Views)
This is a duplicate thread: http://forums.ni.com/t5/LabVIEW/Multicolumn-listbox-jump-1-cell-down/m-p/3341435
Message 4 of 11
(4,265 Views)
I don't think it's irrelevant.  Maybe for moving focus to the next row it is but in order to edit the next row, it is required.
aputman
Message 5 of 11
(4,261 Views)
Multiple thread created
See the reply in below link
https://forums.ni.com/t5/LabVIEW/Multicolumn-listbox-jump-1-cell-down/td-p/3341435
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 6 of 11
(4,228 Views)
The funny ting is that I have an other example without text fokus and without filterevent which works fine.
Have a look on this VI:
Message 7 of 11
(4,226 Views)
Message 8 of 11
(4,226 Views)
Check attached VI. whether it makes your requirement
Message 9 of 11
(4,220 Views)
Thank you 🙂
But actually I want it on key down (return)
Message 10 of 11
(4,207 Views)
