Multipage TIF VIs
I am not sure why you want to keep 8-bits: you are not loosing anything by casting to 16-bit... and if you open the file with e.g. Fiji and stretch it it looks ok.
I will try to modify my VIs to correctly handle also 8 and 32 bit inputs. Might take some time, however!
Best,
Nico
Message 11 of 20
(4,531 Views)
...took much less than I expected... 😉
Here is a corrected version of TIFF_writeMultipage.vi. Please use this one: I tested and it does indeed work with both 8 and 16 bits images.
Enjoy!
Nico
Message 12 of 20
(4,526 Views)
I did a quick test, and yes, it seems to be working. Thank you very much. This helps me a lot.
Message 13 of 20
(4,522 Views)
Great!
have fun and let me know in case you find some other bugs.
Nico
Message 14 of 20
(4,517 Views)
Dear all,
I tried to use the function and it saves multiple images into a single multipage Tiff but in my hands, it saves multiple times the same image.
Message 15 of 20
(4,413 Views)
Hello
In case it helps, i have implemented (from the U16 only version sadly), a VI that doesn't use IMAQ but directly a 3D array to save image. I have tested it and it saves the different z stacks as you want.
Message 16 of 20
(4,050 Views)
That real works well !
And I can open it from Fiji.
But, stupid question : how can I open it back from Labview ?
thanks for your help,
Message 17 of 20
(2,310 Views)
Obviously, this can be done either by parsing the data byte by byte in pure LabVIEW code exactly as it was created, or by using any suitable library that supports it — OpenCV, for example.
Message 18 of 20
(2,307 Views)
But there is libtiff3 that could most probably do the job ?
I didn't find where ti get the libraries for 64bit (and I don't have the skills to compile it)
Thanks for your help !
Message 19 of 20
(2,270 Views)
But, stupid question : how can I open it back from LabVIEW ?
The attached VI loads TIFF file into clipboard.
You can import it from clipboard into 2D Picture Ctrl or .Net Picture Box.
George Zou
Message 20 of 20
(2,250 Views)
