Multiple Uneven 2D XY Graph
I had a problem with graphing a bunch of X,Ypoints. I had multiple 2D arrays. Each 2D array had different number of rows. I came up with this solution (see attached
vis, both 2010 and 2009).
Please let me know if there is a better way. I would have like all of the zeros to go to NaN.
Best option would be to create a 3D array with different size 2D arrays.
CLD Certified 2014
(3,147 Views)
Accepted by ADrexelDragon
Hi ADrexelDragon,
While it is possible to create a 3D array from the multiple 2D arrays, a better way to send data to the XY Graph would be to send an array of clusters.  To do this you would take your 1D array of X points and 1D array of Y points and use the bundle function to create a cluster.  You would create as many clusters as needed and then the final step will be the Build Array function to put the clusters into a single array.  See the bottom portion of the block diagram on the attached VI (LV2010 format).
Anthony F.
Anthony F.
Staff Software Engineer
(3,127 Views)
I knew there was a simpler solution. Thank you!
CLD Certified 2014
(3,121 Views)
