Multiple case selection at a time
Hi jeet,
@User002 wrote:
now i want to select  all three cases. If i select one case at a time its working and getting results as expected
Did you read message #15 (carefully)?
Your VISA communication is a shared resource, it cannot handle several communications in parallel! So again: collect all commands in an array, then send them one after the other...
@User002 wrote:
Can someone explain me how to do like this in the link?
It's the same what we are telling you since more than a month: you cannot run several cases of a single case structure in parallel...
Do you even listen to our advise?
Message 31 of 37
(1,418 Views)
Can you please give me example of it?? So i can understand better
Message 32 of 37
(1,401 Views)
For channel 1 voltage and current im doing the same then i need channel 2 and 3 voltage and current.. so im doing it in parallel..
Message 33 of 37
(1,400 Views)
Hi jeet,
Why do you insist on "doing in parallel" when you describe your requirement as sequential task (first A THEN B)???
Again: your VISA communication does not allow to send commands "in parallel", so send them in sequential order. Collect your commands in an array and send them one after the other...
Message 34 of 37
(1,393 Views)
Scan is the 1st command then there 13 commands which are based on the register of chip to read and write values to register it has hex values those hex values are also can change the channel number. 05 is channel 1, 15 channel 2 and 25 channel 3..
2. Want to send commands for every measurement so when we send the command it will measure voltage and current of chip.
3. Response  of visa read are also hex values. Im using some formulas to convert into the values i want as you can see in sub vis the formulas.
(We can adjust the current  and channel numbers using the commands 11 and 12)
Message 35 of 37
(1,389 Views)
I need it universal. Like A, B, C at time as well
Message 36 of 37
(1,385 Views)
So what's wrong with the advice you were given in another thread from a week ago?
Message 37 of 37
(1,339 Views)
