Multiple event structure
Hello Everyone! 🙂
I am having a headache off this problem.
Example:
I have a value called:Numbers. If i change this value it needs to go to the event structure, and run the "Numbers: Value change"
And I have a button, if this button changes, I want it to run also "Number: Value change"
Is it possible to use more then 1 event. Like: "Numbers: Value change OR Button: Value change"
I can't seem to figure this one out. Could someone tell me this is possible, and if not, how I can solve it?
I hope someone can help me!
Thank you!
Rick
(5,494 Views)
Accepted by Rickvb
Hey Rick
Easy enough to implement. You just need to Add another condition to the event case:
Hopefully this VI Snippet will illustrate this (Simply drag this into LabVIEW - FYI it's made for 2014):
Cheers
J
(5,480 Views)
YES! You are my savior!
I can't believe I did not figure this out myself...
Thank you!
(5,471 Views)
No worries!
Cheers
J
(5,452 Views)
You should not have more than one evet structure in one .vi
You can add more event cases to the same structure, and you can have multiple events for the same event case.
When you edit one event case, then just click on the Add Event button when you have selected the event you what to add to the event case.
Edit: Too slow
(5,447 Views)
