Multiple plots on X-axis of XY graph
Hello
I'm trying to draw multiple plots on an XY graph, which would use same X axis, but with possible missing or extra data points than original X axis.
The X axis is a time stamp and the length of the axis should be the same for all plots, but some data points could be extra or missing.
Like this, except with multiple plots on the same axis.
(1,859 Views)
Accepted by topic author AeroSoul
Hello
What is your question? Where are your difficulties?
https://www.ni.com/docs/en-US/bundle/labview/page/xy-graphs.html
(1,846 Views)
Thanks for the link, that helped.
For info: i had trouble getting multiple plots with different time points on the same X axis. Concatenating multiple clusters is the answer.
(1,834 Views)
Hi AeroSoul,
Building an array of plots is the answer. (You don't concatenate clusters…)
(1,810 Views)
Just making the array of plots didn't work for me (broken wire to XY graph), i had to select "Concatenate inputs" in the Build array for it to work.
(1,782 Views)
Hi AeroSoul,
You still have to build an 1D array of plots, so you use BuildArray in concatenation mode. I wanted to emphasize on your wording as you don't "concatenate clusters"…
(1,773 Views)
