Multiple plots on an Intensity Graph
The graph on the front panel can be configured to have multiple amplitude scales, but I cant figure out how the multiple data sets need to be packaged for the intensity graph to accept them.
(4,084 Views)
Well, if you use multiple graph for an intensity graph, you will see only the upper points of all, so it is useless.
Doc-Doc
http://www.machinevision.ch
http://visionindustrielle.ch
Please take time to rate this answer
(4,084 Views)
The above answer is correct. Although you can input multiple arrays into a regular graph indicator, the intensity graph is already a 2 dimensional graph and so multiple graphs can not be shown on a single indicator. Not to mention what was described above in that you wouldn't be able to see each of the intensities seperately. Hope this helps.
Adam Brehm
(4,084 Views)
