wrong temperature from PXI4350
i used the vi in the attechment, but it doesnt work right. on the connector of the card there is an pt100 resistor.
i the vi is running my values are between -
220 and -240°C.
what is wrong? this vi is from the ni homepage
(2,784 Views)
Are you using an accessory with the board? What's your compensation source? Had a similar problem with a 4351 including readings in that same temperature range when measuring room temp. I swapped it with a known good board and everything worked (eliminated problems with the accessory). Went and bought a new board.
(2,784 Views)
