Multiple sampling - different frequency
How can I read data from 8 analog input voltage channels using the DAQmx, specifying different sample frequency for each channel?
When I open DAQ assistant, I can choose only one sampling frequence for all the channel.
But for example, if I would like to use 8 signals on the same vi for different purposes, using different sampling frequency, how do I do it? Will I need to use 3 DAQ assistant one for each channel?
(3,939 Views)
Accepted by simo28
Hi simo,
you should use just one sample rate for all channels (usually the highest needed or possible) and decimate the signals as needed…
(3,933 Views)
Thank you!
How can I decimate the individual signals?
(3,929 Views)
Hi simo,
there are several functions in the Signal processing functions palette…
(3,927 Views)
