09-12-2012 02:48 PM
Hi all,
I have a LabVIEW exe from a customer where the front panel GUI shows CH0+ being switched to either CH16+ or CH17+ or CH18+. These channel names refer to a PXI-2527. The program and the hardware are working fine, but I thought one of these lines would have to be a Common. How are they using CH0+ as an input and switching it to one of those outputs? What topology would make this possible? (again it's a exe
09-13-2012 06:53 AM
That is confusing. My guess is that they are calling CH0 the common. And since they used +, I would also guess they are using the 2-wire. Again, pure guessing.
09-13-2012 08:30 AM
That's what I have to assume - without opening the wire bundle to ohm it out...
With Independent Topology, could that type of connection happen - connecting This Channel to That Channel without regards to the Commons?
09-13-2012 12:46 PM
Broken_Arrow,
Using the independent topology of the device, you can route the input channels to themselves. Refer to the link I've included below:
NI PXIPXIe-2527 Independent Topology
http://zone.ni.com/reference/en-XX/help/375472F-01/switch/2527_independent/
This is likely what the customer is using.
There is actually a specific message board for any future switch-related questions you may have:
Switch Hardware and Software - NI Discussion Forums
http://forums.ni.com/t5/Switch-Hardware-and-Software/bd-p/320
Have a nice day!
