Multiplot XY graph : error when wiring 24 to active plot property node
I'm using LabVIEW 2009
When I wire 24 or higher to the active plot property node of a multiplot XY graph , I receive error message :
error 1077
Property Node (arg 1) in Untitled 1
<APPEND>
Property Name: <b>Active Plot</b>
Anyone a suggestion ?
(3,428 Views)
how many plots do you have currently plotted? ActPlot can only be as big as the current number of plots...
(3,421 Views)
Accepted by grootverzet
Help>Explain Error... says:
Error 1077 occurred at an unidentified location
Possible reason(s):
LabVIEW:  Invalid property value.
So you're probably trying to control a plot# that doesn't exist in the plot.
(3,418 Views)
