Does Labview provide a polar chart function and can it be used with multiple plots?
I am going to be measuring the runout of a shaft in 4 (simulataneous) locations using the cRIO if possible.
I have 4 linear gauge sensors that have quadature outputs. This is the reason I need the cRIO.
I will be turning a motor 360 degrees through serial commands and measuring the runout of a shaft from 4 locations.
I want to plot the result of this on a polar graph, preferrably with all plots on one graph for comparison.
Is this possible?
Any recommendations?
Jeff
