WinAPI DLLs Documentation
I recently discovered the immense power of the DLLs User.dll, Winmm.dll, Comctl32.dll, and GDI32.dll, all located under system32 in WINNT.  Smiley Surprised  I looked at the functions that they perform and want to use them, but there is very little documentation on their overall funtion and how to set up (in my case) a DLL Interface Node.  Smiley Sad  Does someone know of webpages or have documentation that would tell me:
Their basic funtion and usage
Configuration settings.
I would greatly appreciate some help!  Thanks.  Smiley Happy
7J1L1M
Message Edited by 7J1L1M on 11-10-2006 01:49 PM
Message 1 of 13
(6,220 Views)
Try here.  I've found their developer network/help stuff a bit clunky, so be prepared for a bit of digging.  This should be a good start though.
Message 2 of 13
(6,205 Views)
You might also want to take a look at the lvwutil32.zip, available from NI. It contains a bunch of functions using those DLLs.
Message 3 of 13
(6,200 Views)
"I've found their developer network/help stuff a bit clunky, so be prepared for a bit of digging"
Just to make this clear...  I'm referring to Microsoft's DN, not NI's.  NI's is pretty good 🙂
Message 4 of 13
(6,196 Views)
Thanks.  What about the cursor, icon, and tranlucency commands in User32.DLL?
7J1L1M
Message 5 of 13
(6,189 Views)
Search this forum and the general NI site. Examples exist.
Message 6 of 13
(6,185 Views)
Thanks.
BTW, write now I am trying to find a funtion that writes a cursor/icon after using the "CreateIcon" or "CreateCursor."  This is one of the main reasons I want to use User32.DLL.  In other words, I'm working on "ReadIcon," "ReadCursor," "WriteIcon," and "WriteCursor" commands.  Any suggestions?
7J1L1M
Message 7 of 13
(6,181 Views)
Get a book, for example, Charles Petzold's Programming Windows the definitive guide to Win32 API.
http://www.amazon.com/Programming-Windows-Fifth-Charles-Petzold/dp/157231995X
George Zou
http://gtoolbox.yeah.net
George Zou
Message 8 of 13
(6,176 Views)
Hay again,
I am finally figuring out some of the DLL stuff.  Right now I'm working on a right-click menu that comes from User32.DLL, but I'm having trouble defining one of the datatypes.  Could you help me?  The first link below is a link to the function I'm using, and the second defines the datatype I'm working on.  If you can figure it out, would you send it to me as a ctl file?  Thanks.
7J1L1M
Definition of function: http://msdn.microsoft.com/library/default.asp?url=/library/en-us/winui/winui/windowsuserinterface/re...
Definition of datatype: http://msdn.microsoft.com/library/default.asp?url=/library/en-us/winui/winui/windowsuserinterface/re...
Message 9 of 13
(6,163 Views)
Hay again,
I finally found that if you put the correct files into the same directory as the DLL, then the "Call Library Function Node" automatically configures itself.  So what files would I put with say USER32.DLL so when I open it in the Library Function Node, it automatically configures?  Everytime I try to manually do so, I always mess up.  I would greatly appreciate help in this area.
7J1L1M
P.S.  I am using LabVIEW 7.1
Message 10 of 13
(6,061 Views)
