Multisim with Labview
Good evening I'm trying to use Labview with Multisim. I've built the Multisim circuit but when I switch to labview in the Control Design and Simulation\Simulation\External Models I'm not able to find the Multisim palette to browse the Multisim file path. What toolkit or module should I have to install with Labview 2013 to make it appear? In attachment there is the Multisim file.
(4,983 Views)
I have paste the plug-in in the folder path below C:\Program Files (x86)\National Instruments\LabVIEW 2013\vi.lib\Simulation\EMI\Plugins. Now the palette appears but when I try to use it the display prompt that the version of the plug-in is for newer Labview. Anyone has the plug-in for Labview 2013 version?
(4,958 Views)
Accepted by topic author mariorossi
Hello Mario,
here you can find more information regarding use LabVIEW with Multisim: http://www.ni.com/white-paper/13663/en/
I guess you installed a newer version of Control Design and Simulation... try downloading 2013 version: https://www.ni.com/en/support/downloads/software-products/download.labview-control-design-and-simula...
(4,913 Views)
I have the same problem like you, but now I use LabVIEW 2017 x64, with multiSIM 14.1, maybe multisim not support with x64?
(4,771 Views)
