Run executable program on labview
I recently created an executable program that call my two setech cameras (name sentech-test.exe) and take multiple pictures. For simplicity, in Power Shell, I run the program by the command: cd C:/sentech-test.exe0 (0 and 1 basically specify which camera I am using). I try to call the program via  Labview using System Exec.vi by using the command: cmd\C dir C:\sentech-test.exe0 but the program was not executed. The command window turn on and off very quickly. Do you know how to fix this problem?
Also I am using window 10 computer
Toan
Message 1 of 13
(8,024 Views)
Hello Tom,
Quick question: Are you running LabVIEW with administrator privileges?
Have you checked this Knowledge Base article: How Do I Run an Executable or External File from within LabVIEW?
Randy @Rscd27@
Message 2 of 13
(8,000 Views)
Hi
I am not running LabVIEW with administrator privileges. Also thank you for the document link. I think it is right on my problem. Do you by chance how to create the .bat file to execute the .exe?
Message 3 of 13
(7,984 Views)
Hi Tom,
I believe this document could be useful: How to make a batch file
Randy @Rscd27@
Message 4 of 13
(7,980 Views)
Thank you for the document about batch file. It is reaIly helpful. I was able to create the batch file. I tested the batch file and it run just file (it open the camera and take picture). However, when I try to call the batch file via labview using the command: cmd /c  dir C:\Users\toanle\Documents\sentech-test.bat but the batch file was not executed. do you have any suggestion on how to resolve this
Message 5 of 13
(7,967 Views)
You don't actually have "dir" in that command do you?
Message 6 of 13
(7,952 Views)
I try to run both with dir and without dir. it still did not execute
Message 7 of 13
(7,947 Views)
I am not sure of the right syntaxis for calling options in the batch file, but I will like to know if you are doing it like this:
or
C:\sentech-test.exe -0
I am not sure if this would matter.
Randy @Rscd27@
Message 8 of 13
(7,944 Views)
I used sentech-test.exe 0. I am pretty sure that is the correct syntax since if I try to use sentech-test.exe-0, the batch file will not run. You mentioned before about running labView with administrator privileges. Would it be matter? how can I do it?
Message 9 of 13
(7,940 Views)
Also, I am kind of confused. If I specify my path in the command, I dont have to list anything in the working directory right?
Message 10 of 13
(7,938 Views)
