Multithreading tcp connection
I'm building a labview server that communicates with a java client.
The communication works but I have 2 problems:
- Labview writes only string via tcp, so I cast Double to String, but when I try to read it reads a wrong value. Someone knows what kind of stream I can use in java?
- How can I obtain a multithreading server? After the first read I need to wait for other events, that will arrive during the execution of the program.
  I tried with two while loop with 2 tcp listener on different ports, but it didn't work.
Thanks for your help,
Veronica
Message 1 of 12
(6,009 Views)
Veronica
Hi Veronica,
It could be the byte order that messes it up for you?
Try to flip the order before you send it and see if it works?
A few LabVIEW/Java links:
http://lavag.org/topic/2723-tcpip-java-labview/
http://forums.ni.com/t5/LabVIEW/problem-with-tcp-server-sending-data-to-java/td-p/1102302
An example object oriented threading example:
https://forums.ni.com/t5/Example-Code/Object-Oriented-Threading-Using-LabVIEW/ta-p/3517625
What you can do there is spawn/create a new thread with each incoming connection.
Br,
/Roger
Message 2 of 12
(6,007 Views)
I had already seen these examples on java. Tomorrow I will try to reverse data, because here in Italy it's late.
Then, I don't understand this multithreading VI... I thought that I have to do something simpler.
I attach my idea. Is it totally wrong?
Message 3 of 12
(5,999 Views)
I think you are using a Apache Tomcat/proxy port?
Perhaps you should move to ports in the range:
http://en.wikipedia.org/wiki/List_of_TCP_and_UDP_port_numbers
It's common to have an inner tcp read loop, and to go back listening when your tcp session ends.
http://www.ni.com/white-paper/3982/en
https://www.ni.com/en/support/documentation/supplemental/06/basic-tcp-ip-communication-in-labview.ht...
Br,
/Roger
Message 4 of 12
(5,993 Views)
I read these examples, but connections are put in a queue and I need to manage 2 connection in the same moment.
I attach a little "summary" of my program.
I need to:
- Read the command "ON0", create a file and acquire data using a DAQ. These data are written on file and also via tcp, so the connection must be active.
- Wait for events. Events will activate the case structure that writes event on file.
Can someone explain me clearly what I need to do?
I'm a beginner with labview but I have to finish this program this week because I must send my thesis to my professor.
Thank you and sorry for my english.
Message 5 of 12
(5,966 Views)
Is there anyone?
Message 6 of 12
(5,944 Views)
If you want N clients to each communicate with a dedicated instance of your server, then you must the set the server VI to be "re-entrant". Then, when a client connection is accepted, you spawn a new server instance and pass it the connection reference.
Message 7 of 12
(5,934 Views)
What's the meaning of "re-entrant"??
Message 8 of 12
(5,923 Views)
Re-entrancy means the VI can be "cloned" aka "spawned", that is, multiple copies of the VI can be in memory at the same time. You can set this property under "File...Properties...Execution (Reentrancy). Since you want each server instance to have its own data (not shared), use the "Preallocated clone" option.
The way I did this was to have a listener VI that dynamically calls the server VI when a connection is accepted. The listener VI passed the connection reference to the new server instance.
Message 9 of 12
(5,916 Views)
thanks for your reply.
I try to follow your advice and I did the "complete program" re-entrant.
I attach the server, but the tcp listener stops the execution.
What's wrong? I don't know what to do Smiley Sad
Message 10 of 12
(5,900 Views)
