My OI build creates my exe with no errors but when I run it I get a Path not found. pop up
The specifics
Labview 2022
TestStand 2021
Windows 11 Enterprise
National Instruments install and project files are on the D drive (my C drive isn't big enough to handle the environment.)
I have a test stand/labview app that runs fine, test UUT works as expected and when I build the OI project, it builds without error and creates the exe file as expected.  When I run the exe I get my main OI window and in a few seconds a pop-up window that says "Path not found." and nothing else.
I am upgrading old NI2013 code to TS2021/LV2022.  My build folder is on the D drive and all my VIs are called from TestStand using relative addressing.  When the project build is done, it creates a folder in the C drive and the build info says /C/... which sounds like a problem I don't know if it is.  This build creates a .exe, a .ini and a .aliases.  Other projects I have built had a Data folder, but I don't know if that is a requirement.  I tried changing the build to put the executable on the D drive, which it did, but gave the same error.
I am not a hugely experienced TestStand developer and I am working with 12 year old files and no access to the original authors so I am not sure what rules I may have violated.  Do I have to have my NI install and project on the C drive for this to work?
Any pointer appreciated.
be well,
DLC
(216 Views)
Accepted by topic author DLMC
The problem is that there are direct paths specified in the OI that I cannot change because they are used with directX calls.
Creating a hard-link in the C:\ drive to the development folder allows everything to work in the dev. environment.
be well,
DLC
(120 Views)
