My Terminal VI to serially connect to Linux box won't login
wiebe@CARYA wrote:
The shift register with the \n, \r\n, \r construction is a bit uncalled for. You might as well read the enum in the send event when it's needed. No need for the SR nor the 'termination string' value change event.
But you can use the shift register to add characters in the key down event. Don't send the characters, but add to the string. Unless it's an enter, then send the string and clear it...
Not really a satisfying solution, as it should work character by character, but it would get the job done.
The shift register with the \n, \r\n, \r construction is only for troubleshooting purposes to test out different terminations. I have determined that /r is the correct termination and removed the shift reg and event.
Message 11 of 16
(1,130 Views)
That's pretty logical after showing the Teraterm configuration. You have there a CR configuration for both sending and receiving and that is of course the "carriage return" character, not the "new line" character. And "carraige return" is in \ notation the \r.
Rolf Kalbermatter  My Blog
Message 12 of 16
(1,122 Views)
I found the original problem of the password not working correctly. Because the password had capital letters the keypress event was adding the single press of the shift key to the password. While working on getting Ctrl+Z to work I discoverd that Crtl+z was capturing two characters. When I eliminated the cntrl press I then realized that shift was doing the same.
Message 13 of 16
(1,106 Views)
nice job!
Bill
CLD
(Mid-Level minion.)
Message 14 of 16
(1,102 Views)
Thanks for posting the solution... One more thing left to do...
Spoiler
Message 15 of 16
(1,088 Views)
Accepted by topic author Viper
I solved this problem by using the http://www.ni.com/example/28924/en/ keydown.vi as a starting point. Attached is how I handle the shift and control keys.
Message 16 of 16
(1,063 Views)
