Number of steps of acquired data
please make it a moment that I look for the solution.
I am acquiring the data of 4 sensors and I save my data in excel files, the problem that I want to sort my data that I have in labview for example take only one measure between 4 measures
Thank You very much for you help Heart
(2,607 Views)
I'm afraid I don't understand what you are asking for.
What is "for example, only take one measure between 4 measures"?
(2,583 Views)
I am acquiring 10,000 measurements and I want to sort out my measurements. I want to take a measurement by each 4 measure.
thank you for your help ❤️
(2,565 Views)
Accepted by topic author Omaribder
If I'm understanding you correctly you want every 4th measurement to be logged, but not all 10,000. (so like 4,8,12,16, etc...)
The simplest way is to use the node "Decimate 1D Array." You can resize it and take the 4th one. This will give you all the 4th measurements from the 1000.Solution.png
(2,562 Views)
I think it's the right answer
thank you so much
(2,554 Views)
