My cRIO9082 cannot be connected, and its status in the NI MAX shows 'inconsistent IP settings'
No, I am afraid not. All the PC cannot connect with RIO through network, but can connect directly through the RJ45 cable.
Message 11 of 15
(948 Views)
And what are the IP address of the RIO when connected to the network?
Message 12 of 15
(944 Views)
It's 10.0.180.105, which is read through NI MAX, although the status shown 'inconsitent IP settings' on NI MAX.
Message 13 of 15
(943 Views)
Accepted by topic author RongZou
So you have:
PC = 143.167.235.134
RIO = 10.0.180.105
Then they are not on the same subnet.
If you stick with the PC settings of 143.167.235.134, then your RIO need to have a IP in the range of 143.167.235.1 to 143.167.235.254
If you stick with the RIO setting of 10.0.180.105, then your PC IP needs to be in the range of 10.0.180.1 to 10.0.180.254
Message 14 of 15
(938 Views)
Now, my PC's address is 143.167.182.188.  I tried to set my RIO's address to be 143.167.182.180. This really works. Thank you!
Message 15 of 15
(931 Views)
