My chart has only 9 elements... What can I do?
When I add data from an auto-indexing "For" loop, through an "array to cluster" into a chart, I only get 9 plots.   I am supplying 20 data points and I only see 9.
 I know it has something to do with the "array to cluster" function, but what can I do to fix this problem?
(2,630 Views)
Don't convert the array to a cluster, just combine your data points into a 2D array and wire it to the chart. See the attached vi where three different ways of wiring a multiplot chart are presented.
Chilly Charly    (aka CC)
(2,628 Views)
Good reply CC. For completeness, the solution using clusters is to Rigth-Click on the Array to CLuster node and set the cluster size to 20. Unlike arrays, the cluster size is fixed at edit time.
LabVIEW, C'est LabVIEW
(2,617 Views)
