My filter always alarms
All right. I upload the VI and could you examine it?
Message 11 of 20
(1,003 Views)
Hmm. I upload the vi and could you help me examining it? Thanks.
Message 12 of 20
(1,000 Views)
I don't have a DAQ handy, which VI is giving you the issue?
Charles Chickering
Architecture is art with rules.
...and the rules are more like guidelines
Message 13 of 20
(998 Views)
Filter VI is the trouble which i found but DAQmx is just being used to acquire data.
Message 14 of 20
(995 Views)
Why can't you use a bandpass where you can set the high and low limits rather than two separate filters? Also, wire an indicator up to your waveform and then run your VI. Stop the VI and change the indicator to a constant and leave the constant on the block diagram. That way we have data that's causing the problem. Will be much more helpful in debugging.
Message 15 of 20
(991 Views)
I'm having a great deal of difficulty even reading this VI. Was it written in a language requiring 2-byte characters? All of the text labels are screwed up and I can't make heads or tails of them.
Charles
Charles Chickering
Message 16 of 20
(987 Views)
Charles
I had the same issue. If you turn on context help, you can find the two filters in the lower part of the big while loop. I couldn't find them by the name because that was messed up in context help too, but the descriptions werent so I read those.
Message 17 of 20
(983 Views)
I am not able to run the code on my end. I cannot get the text in the VI to display correctly regardless what I try. Can you place the "Get Waveform Components" after the DAQ acquire data and display the delta t and let me know what that says?
Charles Chickering
Message 18 of 20
(982 Views)
I can't, unfortunately I don't have the hardware. I could set up something simulated in MAX but it would be a lot easier if the OP just takes some data and saves a constant so we don't have to be taking our time to guess!
Message 19 of 20
(978 Views)
I'm sorry but the lab was written in Chinese though it does not matter.
Message 20 of 20
(973 Views)
