My program runs fine in Win 98 computer that has only 348 MB of system memory, but I get -10444 error when I run my program in new WIN XP computer that has 1GB of memory. My AI config buffer size is 1E7. I am using LabVIEW 6.02.
Yes, the NI-DAQ versions are same that come with the LabVIEW 6.X software. I have removed the LabVIEW 6.02 software from my old win 98 computer, and installed it to the new Win 2000 computer.
(2,941 Views)
I've seen this error before on Win2000 and XP when buffer is larger than 15MB. The only solution is to try not to make such a large buffer. Instead, use a continuous generation in order to allocate a smaller buffer.
Also, remember that LabVIEW makes a copy of the buffer in user memory which could also be contributing to this behavior.
Zvezdana S.
(2,941 Views)
