Does the DAQpad (MIO-16XE-50) support analog triggering?
I need to use an analogue trigger with my DAQpad but when I start experimenting with the "Acquire N Scans Analog Hardware" vi, and select any channel (ACH0, PFI0, PFI1) as the analog input, AI Trigger Config complains -10403 - device doesn't support this mode.
(2,854 Views)
The board only supports digital triggering. In case you lost the user manual, you can get a copy here.
(2,854 Views)
Thanks - I did RTFM, but didn't interpret "configured as edge detecting" to mean "strictly limited to digital triggering". Dang - could have saved a weekend with a more careful reading! Thanks,
(2,854 Views)
If all you need is a single analog trigger point, then an external comparator would work. If you need a variable trigger and if you have spare analog output, you could wire that to be the comparator's reference.
(2,854 Views)
Hello;
That board doesn't support Analog Triggering.
That information can be found on the Users Manual of that board.
Filipe A.
(2,854 Views)
