My vi always overwrite on the same file
My vi filled an array inside a loop, and when it is ended then he have to record the array in a lvm file. My problem is that it always overwrite on the same file instead of increment its name as confirured in the 'Record Main.vi'
simplified "Rempli_Global_Vol_Tot.vi' :
Peter.
Labview 2010
Message 1 of 10
(4,097 Views)
Peter,
your Record Main.vi contains the ExpressVI Write To Measurement File. This is configured to a static file (C:\Users\Escape\Dropbox\Débit_Mesuré.lvm). Since you are not writing anything to the file using this VI, but only ask for the file path, it is no surprise that you will always get the same file over and over again.
Suggestion:
- Use the Write To Measurement File to write the data.
- Replace Write To Measurement File with code which returns unique file names.
- Possibly (not tested) it is sufficient to add a boolean constant to "Reset" of the Write To Measurement File and set it to "TRUE" (default is FALSE).
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 2 of 10
(4,089 Views)
And when I run "Record_main" alone, he create a different file at the end of each execution. That's how it should work.
Peter.
Labview 2010
Message 3 of 10
(4,088 Views)
Thank you for your answers Norbert,
How can I your second suggestion  ?
Peter.
Labview 2010
Message 4 of 10
(4,082 Views)
I see you are writing to a text file as well to avoid overwriting you have to set the file position before writing to the file. Try the attached example
Write the data into the after setting the file position.
Message 5 of 10
(4,080 Views)
I understand that he wants a new file each time with an unique name (e.g. with increasing number in its name).
Is that correct?
Norbert
Norbert
Expert: Geometry
Message 6 of 10
(4,076 Views)
Yes you're right Nobert !
Peter.
Labview 2010
Message 7 of 10
(4,074 Views)
Peter,
to implement your own code for unique file names, you have to use the "Check If File Or Folder Exists.vi" from the advanced file io palette:
Depending on its result, you will count up, check again and so on and so forth....
You would pass the first "free available" file name to your Write To File function.
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 8 of 10
(4,072 Views)
Thanks Nobert but I'm a new user of Labview so i'm not sure to understand how I can add this function to my vi,
can you show me how can I do that please ?
Peter.
Labview 2010
Message 9 of 10
(4,067 Views)
Accepted by Peter Saraiva
Peter,
the code would look similar to this:
Norbert
Norbert
Expert: Geometry
Message 10 of 10
(4,059 Views)
