MySQL Connection Error
I am new to labview and database programming. I am trying to retrieve the data out from mysql database and show it on labview. I keep getting an error message and i am not sure how to fix it.
 Please kindly advice. Thank you.
FYI:
I am using:
32 bit labview 2012 and
64 bit ODBC connector
(3,841 Views)
Accepted by S.Neo
If you are using 32-bit LabVIEW, you need to use the 32-bit ODBC connector.
Install the 32-bit connector, then run the 32-bit version of the ODBC administration tool (c:\Windows\SysWOW64\odbcad32.exe) and set up your connection from there.
(blog)
(3,809 Views)
