Myrio keypad Error
i have create a Labview VI on my MyRIO for read a 3x4 Keypad. If i start the vi i get this error (See screenshots)
What i have doing wrong?
(3,499 Views)
Did you drop any probes on the error wires to see which function is throwing the error?
(3,453 Views)
Hi Saiz,
You did not read the manual
(3,427 Views)
I have read this error code explanation.
Sorry i'm new in Labview and not understand what this means.
It this because i have multiple VIs on the myRIO?
If i put all code in Main.vi it will be ok?
How i can use another VIs?
(3,419 Views)
Are you saying you don't understand what it means to put a probe on an error wire?
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
Learn LabVIEW
@Saiz wrote:
It this because i have multiple VIs on the myRIO?  Possibly.  Who knows.  You haven't figured out where the error is coming from yet so we can have a clue.
If i put all code in Main.vi it will be ok?  It wouldn't hurt.
How i can use another VIs?  I don't know what other VI's there might be.
(3,404 Views)
