Mysql syntax error.
Greetings,
This is my first attempt at DB programming with MySQL, and I'm getting a "syntax error".
I'm using the modules from the LV DB connectivity kit.
About me:
Labview 7.1
WinXPsp2
MySQL 4.1.15
ODBC 3.51.12
Possible reason(s):
Exception occured in Microsoft OLE DB Provider for ODBC Drivers, [MySQL][ODBC 3.51 Driver][mysqld-4.1.15-nt]You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'image,LVDT1 float,LVDT2 float,Thickness float)' at line 1.  in Conn Execute.vi->DB Tools Create Table.vi->DB Tools Create Table If Not Exist.vi->DB Tools Insert Data.vi->Karona-500884.vi
Other apps are able to communicate with the MySQL database, so I don't think it's an issue with the DB. Maybe ODBC configuration? I can connect fine, and I can list tables and whatnot, but the block of code pasted below fails.
Here is the code that creates the error:
Thanks for any input.
Ryan Wiersma
(3,189 Views)
I figured it out.
I was under the assumption that the INSERT command would create the table automatically (which it DOES do), but it wasn't creating it with the proper type definitions.
So, I included a table-create command, setup the proper defs, and now it's working. I get an error on every run except the first run (the table is already created, I can't create it again). So I put a clear-errors command right behind the create-table command. Now everything works well.
-Ryan
(3,177 Views)
