N Queens (Backtracking)
My solution to the N Queens Problem (with Backtracking)
(N_QUEENS_MAIN.vi)
Message 1 of 9
(5,172 Views)
Hello ouadji,
Is there something we can help/assist you with?
Or did you just felt like sharing the code? 🙂
Is it related to a coding challenge that I'm not aware of?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 2 of 9
(5,137 Views)
no, thank you.
yes, just to show what I did. Smiley Happy
no, I did this just for fun
Message 3 of 9
(5,129 Views)
Could you provide a description of what your code does and waht N Queens (Backtracking) means?
Message 4 of 9
(5,119 Views)
From here:
http://www.roard.com/docs/cookbook/cbsu6.html
"The n-queens problem consists in placing n non-attacking queens on an n-by-n chess board. A queen can attack another queen vertically, horizontally, or diagonally. E.g. placing a queen on a central square of the board blocks the row and column where it is placed, as well as the two diagonals (rising and falling) at whose intersection the queen was placed."
Message 5 of 9
(5,115 Views)
Hehe 🙂
Kind Regards,
Message 6 of 9
(5,086 Views)
Thank you for(imstuck)
because my english is not very good.
This would not have been easy for me to explain it.
soon, a sudoku solver Smiley Happy
Message 7 of 9
(5,070 Views)
Hi Ouadji,
On this forum "Thank you" is best expressed in Kudos (that star under the avatar). They can only be earned and are welcome by most. No translation required.
Ben
Message 8 of 9
(5,064 Views)
ok Ben, understood  Smiley Tongue
Message 9 of 9
(5,034 Views)
