NEED CHART WITH 1-MINUTE TIME X AXIS
Your code still needs a lot of work and I am sure once the code is cleaned up and the recommendations of other followed, things will fall into place.
  • You still have several diagram constants that are DBL, causing all these coercion dots and elevating all data structures to DBL.
  • Why is the tab terminal inside the FOR loop? Pointless!
  • A one minute wait makes the UI unusable. It might take up to 2 minutes to react to e.g. the stop button.
  • Why can't you just reshape the 2D array to 1D and use a single FOR loop?
  • You probably want an empty case as default, just to be sure. (I doubt you even need a case structure!)
  • You still set the offset every 60 seconds instead of only once.
Can you run your VI until "RegisterValuesUI 2" contains data, stop the VI, make the current values of "RegisterValuesUI 2" default, save under a new name and attach it here. This gives us something to play with.
Message 11 of 18
(1,102 Views)
Thank you so much for your help it means a lot to me because I am still new in LabVIEW.
I dont understand what that means, which one diagram constants?
While correcting the program, I put it accidentally  inside FOR loop.
I read somewhere on forum that Wait function need to be the same as offset, so I put it.
I have 8 inverters (from 2 different producers) in my PV system. All of them have different IDs and IP addresses, so I need make initialization for each separately. The rows show one inverter so I use 2 for loops during loging data; First one for choosing inverter and the second one for reading each measurements individually.
I need case structure because of reasons mentioned above (different inverters - different IDs and IPs) and some data should be scalared with different values. if you have a better and more efficient method to reduce the number of cases, I will appreciate your help. I will upload my Read1scada(subVI).vi and InverterInit (SubVI).v
Sorry, my fault.
Tomorrow I will run the program in the lab and send the desired .vi with data.
Thanks again and I accpet all sugesstions and help from you and others experts. 🙂
Message 12 of 18
(1,095 Views)
upload as you say, the current values of "RegisterValuesUI 2".
Thanks!
Message 13 of 18
(1,067 Views)
Sorry, this is way too messy to do any reasonable work on my 1080p laptop screen. Why is the front panel set to a minimum width of almost 3k pixels and a gigantic height? I can't even bring the bottom scrollbar into view!! Why is there so much code duplication? (e.g. that swarm of property nodes near the top could be replaced by one, iterating on an array of references. You still have all these coercion dots. You still have all these local variables. Why are there so many overlapping front panel elements?).
Message 14 of 18
(1,056 Views)
Hi mojmalije,
@altenbach wrote:
Sorry, this is way too messy to do any reasonable work…
Yes, it is!
Example before:
and after:
Is your coding style considered "readable"?
Message 15 of 18
(1,050 Views)
I am so so sorry, because I uploaded my old application accidentally. This one is my new and now it works correctly, but I want to make my program more efficient and reliable.
Message 16 of 18
(1,032 Views)
Hi Mojmalije,
Several items:
  • don't use SGL indicators for DBL data (like "user 3" array indicator): avoid coercion dots, expecially on array data…
  • having a 20s wait in the main loop will make your program very unresponsive to user actions: use a shorter wait!
  • use reasonable datatypes: why does your Inverter configuration cluster store unit IDs as DBL value when you need tham as U8 datatype?
  • do you really need an array fo error clusters? Why not use a scalar error cluster in the Read1Scada subVI? You also should check all shift registers: some are NOT initialized…
  • I would avoid local variables, like in state 28/29 of your large case structure.
  • Don't hide control labels in the block diagram: hidden labels reduce code readability!
  • I would hide the labels of subVIs/functions to improve code readability: use the context help window to learn subVI/function names!
  • use diagram sublabels to provide code comments!
Message 17 of 18
(1,020 Views)
Thank you so so much for this comments, they are really helpful!!! I accept all of them, but I have 2 questions.
    • When I put shorther or different time in the main loop then time for the Multiplier on Property Nodes for chart, then my chart show data  faster then real time. For example, if it is now 11:22h, on my chart it shows data for 11:37h.
    • What alternative I can use?
Thanks a lot, I really learn a lot with your advice!
Message 18 of 18
(1,003 Views)
