.NET-Error when invoke "tiepie_hw_init" from TIEPIE_HW_API
I'm using the follow software products:
When I try to initialize the API with invoke node "tiepie_hw_init", I receive the follow .NET error:
"Invoke Node
Exception has been thrown by the target of an invocation.
The type initializer for 'TiePie.Hardware.API' threw an exception.
Stack Trace:
at TiePie.Hardware.API.tiepie_hw_init()
at InvokeStub_API.tiepie_hw_init(Object, Object, IntPtr*)
at System.Reflection.MethodBaseInvoker.InvokeWithNoArgs(Object obj, BindingFlags invokeAttr)
in TiePie.Hardware_DotNet_Init&Close.vi"
Details are shown in the attachment. Has anybody a tip, what's the reason of this? Thank you in advance
Christian
Message 1 of 10
(313 Views)
since tiepie_hw_init is black you should click on it. Then choose from the method list appropriately.
Actor Framework
Message 2 of 10
(260 Views)
The method was selected correctly (see attachment). The method in the Invoke node was also executed, but returned the described error.
Message 3 of 10
(223 Views)
The comment in your code does mention .net framework, not code. Are you sure your dll is .net core?
If both are available choose freamwork, since core support is not good.
Actor Framework
Message 4 of 10
(214 Views)
Thank you for response. "Select Class >> .NET Core" is the only way to load the "TiePie.Hardware" assembly.
I tried to load the "TiePie.Hardware" assembly via "Select Class >> .NET Framework", but it returnes an unspecified error (see attachment).
Message 5 of 10
(206 Views)
according to
https://www.nuget.org/packages/TiePie.Hardware#readme-body-tab
there is a .net 5 framework version of the lib. Either download it from nuget via e.g. visual studio and locate where nuget has put those or ask the manufacturer to send you appropriate files.
Actor Framework
Message 6 of 10
(192 Views)
I realized .NET version naming is not easy to understand. I am not sure if a tiepie .Net Framework version exists. If not you have to wait for proper core support in labview. I guess this takes at least 2 more years from now.
Actor Framework
Message 7 of 10
(175 Views)
I downloaded TiePie.Hardware 1.0.11 (https://www.nuget.org/packages/TiePie.Hardware/1.0.11), the newest version for .NET 5.0. Folder lib in this package contains four versions of TiePie.Hardware.dll:
  • net5.0
  • net6.0
  • netstandard2.0
  • netstandard2.1
I tried to load all of them.
"Select Class >> .NET Framework" leads to the known unspecific error (see attachment 1).
"Select Class >> .NET Core" is able to load all of the four versions. But execution of any invoke node results the known .NET error (see attachment 2).
Message 8 of 10
(134 Views)
Accepted by CDietz
Solved:
From the folder structure of TiePie.Hardware NuGet Package (https://www.nuget.org/api/v2/package/TiePie.Hardware/1.5.1) I copied the files
  • ..\tiepie.hardware.1.5.1\lib\netstandard2.1\TiePie.Hardware.dll
  • ..\tiepie.hardware.1.5.1\runtimes\win-x64\native\*.dll
in a new common folder. Then I selected TiePie.Hardware.dll via .NET Core from this new location. Now all invoke nodes works properly. It seems that .NET Core expects all DLL files to be in the same folder.
Message 9 of 10
(21 Views)
LabVIEW should throw an error if TiePie.Hardware can't find a dll it was linked to. I encourage you to contact NI support with this.
Actor Framework
Message 10 of 10
(13 Views)
