.NET Framework 4.5 support
I just started to develop my first .Net dll.
I want do call it from LabVIEW. I want to use an external dll in .NET Framework-Version 4.5.0. So my dll will be also in Version 4.5.0.
At the moment I'm using LabVIEW 2013.
I think LabVIEW does support the .NET Framework until Version 4.0. But some Features of the Version 4.0 will be not supported. So these Features can not be used from LabVIEW.
Version 4.0 is now more than 5 years old.
Is there a way to use Version 4.5? Is it officel supported?
From post  https://forums.ni.com/t5/LabVIEW/Unable-to-load-NET-4-5-assembly-in-LabVIEW-2013/td-p/3059420/page/2 I reason that it is general possible.
What are the restrictions?
Regards
Sletrab
(7,342 Views)
Accepted by topic author sletrab
It is possible to specify the version of .NET that LabVIEW uses: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LDcSAM&l=en-US
Note that some features are not supported: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8iWSAS&l=en-US
(blog)
(7,318 Views)
Thank You Sam_Sharp,
A very quick and helpful answer!
Sletrab
(7,303 Views)
