.NET WPF and Labview are boggling my brain
Does this mean I can't do what I want?
No. I mean you might want to just skip create constructor.  Go directly to property/invoke node.
George Zou
Message 11 of 32
(1,924 Views)
Without a constructor to make an object, what reference do I feed to the invoke and property nodes?
Message 12 of 32
(1,921 Views)
You don't.
George Zou
Message 13 of 32
(1,918 Views)
Just config an invoke node like a constructor.
You can get a system color like this, without constructor.
George Zou
Message 14 of 32
(1,915 Views)
This assembly depends on a module called RapidCode (yes seriously, that is not a joke) that you did not include in your post. Not sure what it exactly is, it could be a functional DLL or another assembly DLL.
Without that it definitely fails to be loaded.
Rolf Kalbermatter  My Blog
Message 15 of 32
(1,909 Views)
Hi again, thanks for your help!
I do not know C# well enough to understand why dependency on a module could be a joke.  How did you discover that? I'd like to follow up on my own.
Message 16 of 32
(1,872 Views)
Download Dependencies from here: https://github.com/lucasg/Dependencies/releases/download/v1.10/Dependencies_x64_Release.zip
Then put it somewhere on your computer and startup the DependenciesGui.exe program in there. And then put your DLL in there (just drop it on the window from an Explorer window).
Message 17 of 32
(1,857 Views)
Well that is interesting.  DependenciesGUI does not find any dependencies in the rapidcode64.net.dll at all.
Message 18 of 32
(1,846 Views)
Did you download the file? Go into explorer and right click on the DLL. Display the properties dialog. Do you have a checkbox on the first tab saying Unblock this file? Check that, confirm and try again.
Message 19 of 32
(1,833 Views)
Does this version of Dependencies work on Win7?
I got an error when I drop any dll on the window.
George Zou
Message 20 of 32
(1,827 Views)
