.NET WPF and Labview are boggling my brain
@larry_koler wrote:
The example code from them uses the NetworkStateGet() prior to starting the network so shouldn't be a problem there.
I am conversing with the dll provider about those error messages.
I had another look at the DLL provided and noticed an enum in it called "RSIErrorMessage".  If you look at all of the numeric values in it, turns out error 5124 is the value for the enum named "RSIPlatformMessageDEVICE_ERROR".  This may indicate that it's a problem with your device, rather than with your code.
Message 31 of 32
(453 Views)
I want to thank zou, wiebe@carga, and especially kyle97330 for your generous help.
The guy sub-contracting me for this drew a line (at my hours 🙂 ) and is waffling about going to C#, which is not what we thought would happen.
So, I'm giving up.  He took back the equipment I needed to talk to so I can't do any more.  I suggested to him, as a total gamble, that he re-up his subscription and we could try to get NI tech support to look into this; they might still end up saying not doable or practical.
Anyway, thanks again.
Matt
Message 32 of 32
(425 Views)
