.NET assembly problem
My program calls a few .NET assemblies, written in C#.  The assemblies are included in the lvproj that contains the program.  Everything works, until someone sent me an update on the assemblies, and I did a copy and paste to update the assemlies.  Now, when I try to open the main vi, it will look for the assembly in the correct location but will not find it.  When I point the search to the specific assembly, it will not give me an error, but it will not load the assembly into memory.  Anyone knows what's going on?  Thanks!
Kudos and Accepted as Solution are welcome!
(2,955 Views)
Hi jyang72211,
Please refer to this article:
http://digital.ni.com/public.nsf/allkb/90DB53827647F5EE86256D6400599D71?OpenDocument
Carmen Chan
Applications Engineer
(2,912 Views)
Accepted by jyang72211
Problem solved. Apparently, the zip file that contains the dll was corrupted.
(2,899 Views)
