.NET
Hi!
We used self-written .Net Assembly (using .Net 4.0) with LabView 2010. It worked well. Now I have updated LabView to 2013 and can't open the assembly with a rather unclear error (s. attachment). What must I do to use our assembly with LabView 2013? What has changed in this aspect? I attach the error, which I get tryin to open the assembly creating a .Net object with LabView 2013 and the "normal " view as I get it with LabView 2010.
thank you in advance for your ideas and suggestions!
(3,600 Views)
Did you try to unblock the assembly?
Tip: In Windows 7 or later, you also can right-click the assembly and click Unblock on the General tab to grant an assembly full trust.
http://digital.ni.com/public.nsf/allkb/4742EB60B64BE22186257BCE0053B8FD
(3,572 Views)
Thank you very much, Jean-Marc! It is an interesting solution and I'll note it. In the mean time I applied the similar method - creation of the labview.exe.config - with a different content:
<?xml version ="1.0" encoding="utf-8" ?>
<configuration>
<startup useLegacyV2RuntimeActivationPolicy="true">
<supportedRuntime version="v4.0.30319"/>
</startup>
</configuration>
I fount it in the "Help" of LabView and it works. They say, that LabView 2013 loads CDL 4.0, possibly our assambly was created with CDL 2.0 - this configuration script allows to use the older version of the CDL.
I'll try your suggestion too in order to check if it also works.
Thanks and bye
(3,550 Views)
