NI 0207 Module error and LabView code Generation failed to execute
I have a question regarding NI LabVIEW DAQ. I’m using three different modules (NI 9219, NI 9207, and NI 9263) installed across two chassis. Various sensors are connected to different channels of these modules. The issue is that the sensors connected to the NI 9207 module show valid signals in NI MAX or the DAQ Assistant preview, but their values are not displayed correctly on the LabVIEW front panel — instead, I see garbage values or nothing at all. Additionally, when I try to close the DAQ Assistant, I receive an error saying 'LabVIEW code generation failed to execute.' How can I solve this issue?
(815 Views)
Don't use DAQ Assistant. Use DAQmx API. Search DAQmx Examples in LabVIEW
https://tmesystems.net/
(783 Views)
If you can see in the attached image, I am facing this issue now. I don't know how to resolve this. I am using cDAQ 9185, and there are 4 modules in it, and all of them are NI 9219. I am getting a proper signal in NI Max, but here in DAQ Assistant, I am getting this error. How can I resolve this issue?
(755 Views)
Error -209836 in DAQmx Start Task on TSN-Enabled cRIO or cDAQ
(748 Views)
