NI-488: Nonexistent GPIB interface.
Error 7 occurred at Open File+.vi:Open File
LabVIEW: File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS X, and / on Linux. Verify that the path is correct using the command prompt or file explorer.
(4,391 Views)
Duplicate Post
You have already asked this question and are being helped on it.  Why are you starting another thread?
And the subject line is not accurate.  The error is not a GPIB error.  Your other messages are already talking about file paths, so error 7 for a file path error is what you are trying to fix.
(4,380 Views)
the messege againe and againe show on .
(4,374 Views)
Do not continue posting in this thread, or create any more new threads.
Stick with the one thread where you are already getting help.  But for some reason you don't seem to be responding there with any of the questions or tips you were given.
(4,363 Views)
