Determining CPU usage, whether a laptop is plugged in, etc.
   I was wondering if anyone had some example code for reading things into LabVIEW from the OS regarding computer status.  I would like to be able to read things like CPU usage, memory usage, whether a laptop is plugged in or not, battery level remaining, CPU core temp, etc.  I'm sure all these are available through dll's, but I was wondering if anyone had already developed the LabVIEW calls.
    DaveT
David Thomson Original Code Consulting
www.originalcode.com
National Instruments Alliance Program Member
Certified LabVIEW Architect
Certified Embedded Systems Developer
There are 10 kinds of people: those who understand binary, and those who don't.
(3,023 Views)
Accepted by topic author Dave_Thomson
Sure, attached is a couple VIs that do some of the things you want.  There is the get CPU utilization of a process from here.
https://forums.ni.com/t5/LabVIEW/Checking-to-see-if-a-process-is-running/td-p/2834398
Get System Information which I think comes from the WinAP here.
https://forums.ni.com/t5/Example-Code/Windows-API-Function-Utilities-32-bit-for-LabVIEW/ta-p/3996462
And the get battery status which I think was designed for UPSs which comes from the forums but I can't seem to find the origin.
EDIT: This might be better for the UPS which uses .NET
https://forums.ni.com/t5/Example-Code/NET-PowerModeChanged-Notifier-Monitor-your-UPS-or-Laptop-Power...
(2,988 Views)
Thanks, Hoovah!  Excellent references.  I also found a thread where Altenbach mentioned a .NET example in the Example Finder that does some of  this.
DaveT
(2,954 Views)
