ssim
Recently I tested acquired image with the reference image using the provided SSIM.vi from examples. Basically it is an image of 10mm gas bubble at the centre of a pipe.
Below is the setting that I use:
Option: Fast
Window size:3
case#1:
I tested the test (acquired) image which is attachment#1  and the refrence image (attachmenn#2) and the result is 0.3050
Case #2
I test the reference and  test image with the same file which is reference image and the result is 1
Case #3
I test the reference image with other different test image (attachment#3)  and the results is 0.9502
I'm very confused regarding result in case#3 which expected to be near 0. Please guide.
Regards
Message 1 of 1
(3,150 Views)
