I could need some help: I like to use a PCI-6561 HighSpeed Digital IO Card for continous and synchronos data generation and acquisition, but I did not found any example.
The only examples from the example finder are "Continuous Generation - Stream From Memory.vi" and "Continuous Acquisition - Stream to Memory.vi", but I need an example that is a kind of mergence of both examples.
My application requirements are:
- streaming a 8bit wide pattern continously (onboard clock)
- acquire a 8bit wide pattern continously (synchronous to generation -> same clock)
thanks in advance
Andy
