NI 7966R - problem deploying the bitfile.
I have the following set up
PXIe 1085 chasiss with three NI PXIe 7966R FPGAs in it.
I am connected to a remote host via the MXI using a PXIe-8381
I tried running the NI 5761 - Single Sample CLIP.lvproj that ships with LabVIEW examples just to get things up and running.
and I get the following message on all targets ...
Compilation was fine but can't seem to deploy the bitfile ...
Maciej
(3,035 Views)
Accepted by Mac671
Right...  so my bad, I forgot to mention one more thing in my set up.
I had a timing module 6674T which is at the moment seems to be a bit knackered. Since I'm not intending to use it at the moemnt.
I've removed it from the chassis and things started wokring fine.
It seems that it has been causing the issues.
Maciej
(3,007 Views)
Actually I wanted to update this thread.
The timing module wansn't the issue.
The issue was that I put the NI 5761 adapter on the RIO whilst it was powered on...
So had I powered the thing down and plugged the module and powered it back on I would probably never see this.
Right now it's working fine even with the timing module back in the rack.
Maciej
(2,989 Views)
Good to see you are not finding it to easy over there Maciej 😉
David
www.controlsoftwaresolutions.com
(2,941 Views)
good job on with company website 🙂 looks good! 🙂
Hope you're ^^ having it easier back there over the pond 😉
(2,934 Views)
