NI-9188 Issue with Silverlight-Error 2105
Hello all,
I am trying to use an NI-9188 cDAQ chassis. This chassis has been functioning with an old controller, I am updating to Windows 10 and when I try to change the networks setting through NI Max I am hit with the following error:
I am using NI Max 19.5. I have done this upgrade on several other controllers using the same hardware and software and I have had no problem. I have tried using two different controllers to communicate with the chassis and I get the same error. I have tried reinstalling Silverlight on both controllers without any fix. I have tried doing a factory reset on the 9188 and I am met with the same issue. I tried to update the chassis firmware and the revision number went up but the it responds that it failed to update the firmware.
I am able to ping the chassis, run selftest on the chassis and reset it, but restarts fail.
Any suggestions are greatly appreciated,
Churchill
(1,651 Views)
Hi Churchill,
Based on your error code, it may cause by plugin (Silverlight) not being able to run correctly. You may have a look for below most relevant links that found on this issue.
Unhandled Error in Silverlight Application Code: 2105 Category: InitializeError
Message: 2105 An error has occurred:
https://social.msdn.microsoft.com/Forums/silverlight/en-US/ddd74d65-dff1-4b93-89
36-90652f629e4e/unhandled-error-in-silverlight-application-code-2105-category-in
itializeerror-message-2105-an?forum=silverlightgen
Network cDAQ Troubleshooting Resources:
http://digital.ni.com/public.nsf/allkb/E67B4E4749F378FF862577270059BD4B?OpenDocu
ment
Using MAX to change the network setting (IP address) is covered in the following document:
http://www.ni.com/getting-started/set-up-hardware/data-acquisition/compactdaq
Hopeful it can solve your problem.
(1,579 Views)
