NI 9201 signals getting affected
I am using NI 9201 AI module with my 9073 cRIO in scan mode for acquiring 2 signals from power supply. I am facing a peculiar issue. Whenever the signal in first channel rises , it affects the signals in other channels. I have observed an offset of 0.5 v and this ofset rises when the signal in forst channel rises.
I tried isolating the signals using isolations modules but still the signals are getting affected. Is there any way to solve this issue ?
falcon
(3,508 Views)
falcon
Without more details on the setup and the connections we can only guess. It might be a grounding issue.
Ben64
(3,475 Views)
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHy6CAG&l=en-US
Are you using the other channels or just noticing the behavior?
(3,469 Views)
Hi!
I am using 9201 along with cRIO 9075 I need to check the working of 9201. I gave 3 voltage from the Function generator to 9201 but i am not able to get that 3 v in labview the value is random. Can anyone help me with this
Surya S
(3,217 Views)
