NI 9219 : How to use 3 channel simultaneously Voltage measurement
Hi
How can I use the NI 9219 module to acquire 3 analog input voltage at the same time?
You can found in attached the VI I am using to get a single measurement.
(2,728 Views)
Hi zied,
why don't you use a standard DAQmx reference control? Why do you use a string control here?
Use a DAQmx reference, select your 3 channels and change DAQmxRead to read "N channels"…
(2,714 Views)
i'm using this one with a 9201 but you should be able to do it with a 9219 also.
regards
a.m.
(2,711 Views)
