move LEDs and buttons
Best regards to the entire community!
I am currently in a file in LabVIEW for the following:
• Make 2 forklifts carry(buttons) 10 metal containers (LEDs) right side, right side, on a Y type road, that is, as they say at that moment, only one of the forklifts. .
This are my questions:
- Is there any way that the movement of the sea button continues? That is, it has not worked.
- Is there any way to know in what position is the forklift?
- How can I do to drag one of the "loads(LEDs)" and release it in the desired place?
Thank you in advance for your response,
PD: Attachment labVIEW v14 32b
(3,051 Views)
Hi WILSTi,
There is no "sea" button nor do I see any "movement" for any button.
Can you explain which of your buttons you are talking about?
The forklift ("carro 1/2") are moved using those "Position" property nodes. The information you are asking about is in the wire to those property nodes!
By also using  "Position" property nodes of those LED indicators!
(3,041 Views)
@GerdW  ha escrito:
Hi WILSTi,
Hello GerdW,
What I wanted to say is that what I want to do is that the forklifts (which are modified buttons) move linearly, not as they do at the moment they disappear in one position to appear in the other.
Can you explain what buttons you are talking about?
A: Sorry, it was a typographical error, there is no "sea" button. The only buttons I have are the positions, the forklifts (which are buttons modified in appearance)
Thanks for your answer!
(3,032 Views)
Hi WILSTi,
Then you need to move them "smoothly" instead of letting them jump to certain positions!
Using a Ramp function with a loop (with some timing in the loop) will simplify that…
(3,030 Views)
