NI 9237 RTD Measurement
I am using a NI9237 to measure the pressure and temp of a full bridge pressure transducer.  I have the RTD wires connected to the TEDS input.  the Sensor isn't a TEDS enabled device, just a simple RTD.  Can I configure the 9237 to read the RTD?
(3,361 Views)
Hi bedavis144,
This should be possible on your device.  What issues do you encounter when you attempt your readings?
Chris
(3,314 Views)
