system exec.vi broken
For some reason the System Exec.vi does not work any more. There are two errors that I get;
Code Interface Node: Labview subroutine link error
Code Interface Node: Object code is not loaded
When I right click over the Code Interface Node, and select Load Code Resource, it tries to look for CIN's (*.lsb). But I do not know just what and where to find what file I am supposed to load.
Message 1 of 9
(4,622 Views)
Something has changed on your system, if not the programming.  Post your code so we can have a look.
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 2 of 9
(4,619 Views)
There is no code, just the System Exect.vi itself
Message 3 of 9
(4,616 Views)
So how are you using it then?  What commands are you giving it?
Message 4 of 9
(4,608 Views)
Who's been messing around in the LabVIEW directory? Did you or someone else overwrite System Exec? Perhaps with another version?
Try doing a repair of LabVIEW.
Message 5 of 9
(4,598 Views)
In my case the antivirus was blocking this VI, disable the antivirus and the problem was resolved
Message 6 of 9
(4,496 Views)
Don't forget to mark your own post as the solution since it was you who came up with the answer.  This way, you'll be helping others.  🙂
Bill
CLD
(Mid-Level minion.)
Message 7 of 9
(4,477 Views)
Bill,
This was a response to a 5 year old thread and this user's very first post, so it isn't their message.
Message 8 of 9
(4,461 Views)
@RavensFan wrote:
Bill,
Thanks - I didn't check to see if it was the OP that replied!  (Probably the wording should have given it away also.) Smiley Embarassed
But iis a solution - assuming the same error messages and whatnot...  😄
Bill
CLD
(Mid-Level minion.)
Message 9 of 9
(4,449 Views)
