NI 9264 to produce 3 phase waveforms and shown in 1 chart
Hi LVNinja,
When I opened the file, the waveform settings was not saved.
How can I saved the waveform settings so when I open it again, I won't have to set it again as it takes time.
Thanks!
Message 41 of 58
(1,077 Views)
Hi LVNinja,
How can I see the other waveforms in the output graph?
Message 42 of 58
(1,073 Views)
From the bock diagram, You can right lick on the waveform settings and  Change to Constant" this way it will stay hard coded as you setup.
I will check the code soon
Message 43 of 58
(1,053 Views)
- there is a boolean input RESET, that needs to be set to TRUE - I mentioned this before
- the waveform setup array has to have 9 elements (one for each of your waveform -if you make them a constant it will be hard coded so you don't need to setup every time.
Message 44 of 58
(1,047 Views)
Hi LVninja,
I already put the Boolean reset, it worked.
I can make the output array as constant but I have another question.
After pressing STOP, the NI device stopped sending signal but my Equipment still sees some values. The solution is to change the amplitude of all channels to "0" then press start again. Please see the full process below:
Full cycle test of Equipment
1. Set the waveform settings - the only difference is the phase value of each channel
2. Press Start
3. after maybe 2 minutes (this is variable), Press Stop
4. Change the waveform settings - amplitude to zero
5. Press Start
6. Press Stop
Then test the 2nd Equipment using the same process above.
Do you know if I can change the amplitude of all channels in a "single shot" so the process/test cycle above won't take long? or can we design two waveform settings, one is based on item 1 above and the second one is when amplitude is "0"?
Thanks!
Message 45 of 58
(1,036 Views)
Hi Richard,
The solution would be to output "0" AFTER finishing the loop and BEFORE stopping the DAQmx tasks - as part of a "safe shutdown" routine!
Message 46 of 58
(1,036 Views)
Thanks GerdW for your swift reply! 😊
Is it ok if you modify my code (attached) based on your suggestion below?
Thanks!
Message 47 of 58
(1,033 Views)
Can I use the Trigger Settings of the program?
Message 48 of 58
(1,029 Views)
Hi Richard,
See this:
Surely you can use trigger - but what exactly do you want to achieve by using them?
Message 49 of 58
(1,023 Views)
Thanks GerdW!
Do I put the "0" on the time out terminal?
Message 50 of 58
(1,010 Views)
